소개
A broken heat sink can have a result of overheating to your device. This guide shows how to replace the heat sink under the fans within the Dell XPS 15 9510. Allowing the heatsink to cool down the device along with the fans.
Make sure to power off your laptop completely and disconnect from any external power source before to begin the process.
필요한 것
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Using the small battery pull tab, disconnect the battery connector from the motherboard.
Remove the three 4.6 mm screws that secure the heat sink with a Phillips #00 screwdriver.
Lift and remove the heat sink.
Be sure to reapply thermal paste before replacing the heat sink.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
