소개
How to replace the battery of a Dell XPS 15 9530.
필요한 것
1 단계 Unscrewing the Base-Cover Assembly
주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
Remove the screws that secure the battery to the palm-rest assembly.
Disconnect the battery cable from the system board.
Lift the battery off the palm-rest assembly.
다른 5명이 해당 안내서를 완성하였습니다.
