소개
Removal of the battery will be covered in this guide. Be careful disconnecting cables as to not break them or their connectors.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
필요한 것
Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
다른 한 분이 해당 안내서를 완성하였습니다.
