주요 콘텐츠로 건너뛰기
Dell XPS 15 9570 Heat Sink Replacement
필요한 것
  1. Dell XPS 15 9570 Heat Sink Replacement, Base Cover: 1 단계, 이미지 1/1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Heat Sink Replacement: 2 단계, 이미지 1/3 Dell XPS 15 9570 Heat Sink Replacement: 2 단계, 이미지 2/3 Dell XPS 15 9570 Heat Sink Replacement: 2 단계, 이미지 3/3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Heat Sink Replacement: 3 단계, 이미지 1/2 Dell XPS 15 9570 Heat Sink Replacement: 3 단계, 이미지 2/2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Heat Sink Replacement: 4 단계, 이미지 1/1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Heat Sink Replacement, Battery: 5 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Heat Sink Replacement: 6 단계, 이미지 1/1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Heat Sink Replacement: 7 단계, 이미지 1/1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: 8 단계, 이미지 1/2 Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: 8 단계, 이미지 2/2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Heat Sink Replacement: 9 단계, 이미지 1/1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
결론
Margaret Combs
회원 가입일: 09/08/21
504 평판
안내서 4개 작성하였습니다
University of Alabama, Team 2-4, Bedsole Fall 2021 University of Alabama, Team 2-4, Bedsole Fall 2021 회원
UA-BEDSOLE-F21S2G4
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 16
30일 전: 65
전체 시간: 2,324
