소개
This guide shows the process of how to replace the battery in your Dell XPS 15 9575. Batteries are consumable components, that will lose their effectiveness over time. If your battery has a significant amount of charge cycles and is losing its ability to hold a charge for a reasonable amount of time, replacing the battery may give your device a new life. Check out our Troubleshooting Page for more information on issues you may be experiencing with your device.
Be sure to dispose of a battery properly, and if it appears to be swollen, exercise cation removing and handling it.
필요한 것
Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
Use the Phillips #0 screwdriver to remove all four silver 3.2 mm screws fastening the interconnect cable.
Use the Phillips #0 screwdriver to remove all eight 6.4 mm screws from the battery.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 3개
I replaced my battery issue free except for when I screw in the bottom plate my trackpad looses its ability to "click". It only comes back when I completely loosen/ remove the bottom plate... Please advise. Thanks!
I have the exact same issue as Matthew Ormiston, the new Battery seems to be just a bit bigger.
