주요 콘텐츠로 건너뛰기
Dell XPS 15 9575 Interconnect Cable Replacement
필요한 것
  1. Dell XPS 15 9575 Interconnect Cable Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 Dell XPS 15 9575 Interconnect Cable Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 Dell XPS 15 9575 Interconnect Cable Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
    • Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
    • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  2. Dell XPS 15 9575 Interconnect Cable Replacement: 2 단계, 이미지 1개 중 1개
    • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Remove the bottom cover from the device when all sides are free.
  3. Dell XPS 15 9575 Interconnect Cable Replacement, Interconnect Cable: 3 단계, 이미지 2개 중 1개 Dell XPS 15 9575 Interconnect Cable Replacement, Interconnect Cable: 3 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove all four silver 3.2 mm screws fastening the interconnect cable.
  4. Dell XPS 15 9575 Interconnect Cable Replacement: 4 단계, 이미지 2개 중 1개 Dell XPS 15 9575 Interconnect Cable Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully wedge the plastic opening pick between the fan and the interconnect cable.
    • If this position does not release the interconnect cable, slide the opening pick along the edge until it is completely free.
    • Remove the interconnect cable.
  5. Dell XPS 15 9575 Interconnect Cable Replacement: 5 단계, 이미지 2개 중 1개 Dell XPS 15 9575 Interconnect Cable Replacement: 5 단계, 이미지 2개 중 2개
    • Use the nylon tweezers to remove the interconnect pins from each of the circuit boards.
결론
작성자
6다른 기여자 명과 함께
Benjamin
회원 가입일: 09/20/19
322 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 761
