주요 콘텐츠로 건너뛰기
Dell XPS 15 9575 Solid State Drive Replacement
필요한 것
  1. Dell XPS 15 9575 Solid State Drive Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 Dell XPS 15 9575 Solid State Drive Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 Dell XPS 15 9575 Solid State Drive Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
    • Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
    • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  2. Dell XPS 15 9575 Solid State Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Remove the bottom cover from the device when all sides are free.
  3. Dell XPS 15 9575 Solid State Drive Replacement, Solid State Drive: 3 단계, 이미지 3개 중 1개 Dell XPS 15 9575 Solid State Drive Replacement, Solid State Drive: 3 단계, 이미지 3개 중 2개 Dell XPS 15 9575 Solid State Drive Replacement, Solid State Drive: 3 단계, 이미지 3개 중 3개
    • Use the Phillips #0 Screwdriver to remove a single 3.2mm screw from the SSD Drive.
    • You will know the drive is released when the side holding the screw raises.
  4. Dell XPS 15 9575 Solid State Drive Replacement: 4 단계, 이미지 2개 중 1개 Dell XPS 15 9575 Solid State Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully slide the SSD from its port, removing it from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Benjamin
회원 가입일: 09/20/19
322 평판
안내서 2개를 작성함
2가이드 댓글
After replacing the SSD 256GB to 1TB the Power Led started blinking yellow 4 times, white one time when powered by the AC adapter. The internal battery seemes to be disabled somehow. Any suggestions whats missing? Open cover detection maybe? There are no error messages from the bios, windows is running without problems.
micky mouse - 답글
This seemed to be caused by accidentially switching of the little white switch right beside the ssd when placing the ssd into the connector. After switching it on again, it worked as before, no led blinking and running from battery again.
micky mouse -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 17
전체 시간: 2,770
