주요 콘텐츠로 건너뛰기
Dell XPS 17 9710 Lower Case Replacement
필요한 것
  1. Dell XPS 17 9710 Lower Case Replacement, Prepare your device: 1 단계, 이미지 1개 중 1개
    • For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the replacement. If your battery is swollen, take appropriate precautions.
    • Power off and unplug your laptop.
    • Close the display and flip the entire laptop upside-down, with the hinge facing away from you.
  2. Dell XPS 17 9710 Lower Case Replacement, Remove the lower case screws: 2 단계, 이미지 1개 중 1개
    • Use a Torx T5 screwdriver to remove the eight 4.4 mm-long screws that secure the lower case.
    • The lower case is further secured by various clips that must be released before removal.
  3. Dell XPS 17 9710 Lower Case Replacement, Begin to release the clips: 3 단계, 이미지 3개 중 1개 Dell XPS 17 9710 Lower Case Replacement, Begin to release the clips: 3 단계, 이미지 3개 중 2개 Dell XPS 17 9710 Lower Case Replacement, Begin to release the clips: 3 단계, 이미지 3개 중 3개
    • Insert an opening pick at the bottom left corner, between the lower case and the chassis.
    • Insert the flat end of a spudger into the gap created by the opening pick.
    • Pivot the spudger up to release the first set of retaining clips.
    • Repeat this process for the bottom right corner.
  4. Dell XPS 17 9710 Lower Case Replacement, Release the remaining clips: 4 단계, 이미지 3개 중 1개 Dell XPS 17 9710 Lower Case Replacement, Release the remaining clips: 4 단계, 이미지 3개 중 2개 Dell XPS 17 9710 Lower Case Replacement, Release the remaining clips: 4 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap created on the front edge of the laptop.
    • Slide the opening pick around the entire perimeter of the laptop, prying up intermittently, until the lower case fully releases from the clips on the chassis.
  5. Dell XPS 17 9710 Lower Case Replacement, Remove the lower case: 5 단계, 이미지 3개 중 1개 Dell XPS 17 9710 Lower Case Replacement, Remove the lower case: 5 단계, 이미지 3개 중 2개 Dell XPS 17 9710 Lower Case Replacement, Remove the lower case: 5 단계, 이미지 3개 중 3개
    • The lip of the lower case is very sharp. Handle it with care, and try not to slide your fingers along any of the edges.
    • Lift the lower case up and off of the chassis to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Connor Bassolino
회원 가입일: 03/29/22
17,698 평판
안내서 76개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,765개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 110
전체 시간: 615
