소개
First, this should be a last resort for if your computer is overheating and you have ruled out the other two options from the troubleshooting page. This guide is to help you find the thermal paste on your GPU and CPU for when the heat sink is removed.
필요한 것
Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
Four 3.9mm Phillips #1 screws
One 5.8mm Phillips #1 screw
Clean the CPU, GPU and heat sink with 90% isopropyl alcohol dabbed onto a paper towel.
CPU Compound
GPU Compound
Thermal Pad
Heat sink compound
다른 2명이 해당 안내서를 완성하였습니다.
