주요 콘텐츠로 건너뛰기
DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement
필요한 것
  1. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: 1 단계, 이미지 2개 중 1개 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: 1 단계, 이미지 2개 중 2개
    • First, open the metal stand to access the screws without damaging the body.
  2. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 2 단계, 이미지 2개 중 1개 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 3 outer 1.2 mm Phillips #1 screws using a small head screwdriver.
  3. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 3 단계, 이미지 2개 중 1개 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the back casing to reveal the inner circuitry.
  4. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 4 단계, 이미지 1개 중 1개
    • Locate the different parts of your tuner, finding the broken input jack port.
  5. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 5 단계, 이미지 2개 중 1개 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 5 단계, 이미지 2개 중 2개
    • Snip the wires attached to the input jack port using the wire cutter as close to the input jack port as possible.
  6. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 6 단계, 이미지 2개 중 1개 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 6 단계, 이미지 2개 중 2개
    • Take your new input jack port and solder the wires to the corresponding connection areas on the new port.
    • Learn how to solder (here).
  7. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 7 단계, 이미지 2개 중 1개 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 7 단계, 이미지 2개 중 2개
    • Fold the wires back and put the new input port into the slot where it belongs on the tuner.
  8. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 8 단계, 이미지 3개 중 1개 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 8 단계, 이미지 3개 중 2개 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: 8 단계, 이미지 3개 중 3개
    • Replace the casing and 3 1.2 mm Phillips #1 screws using the screwdriver.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Theodore Tan
회원 가입일: 02/24/15
137 평판
안내서 1개를 작성함
Cal Poly, Team 23-4, Green Winter 2015 Cal Poly, Team 23-4, Green Winter 2015 회원
CPSU-GREEN-W15S23G4
7 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 6
전체 시간: 580
