소개
This guide shows how to remove and replace the control module for the Dewalt Nailers DCN660D1 2018.
The module is an all-in-one assembly, which includes the trigger mechanism, battery connector, and selector switch board.
필요한 것
Use a T10 driver to remove the ten screws securing the outer housing.
Lay the device on its left side (with the belt hook).
Lift and remove the right housing from the device.
Be sure to route the wires through the yellow groove.
Be sure to reattach the spring clips.
Carefully flip the device over.
Remove the left housing from the device.
Use a T25 driver to remove the two screws (one on either side) securing the back support .
Use a T10 driver to remove the three screws securing the motor wires
Lift and remove the control module from the device.
Reassembly tip: Make sure that the white plastic actuator latches into the black lever arm.
Remove the white plastic actuator from the control module and transfer it onto your replacement part.
When you install the actuator, make sure the actuator bar can press the white button on the control module.
