소개
This guide will help the user replace the camera. This guide will show how to remove the back case, remove the battery, and the camera without harming the device. Camera replacement is usually needed when the screen is black and the user is trying to take a picture.
필요한 것
Hold the device firmly, in landscape view.
Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
Place the screen in the palm of your hand and then with your other hand carefully grab the case and remove the cover like flipping the page of a book.
Lay the device down and notice that the speaker will be attached to the back cover with a wire. Carefully lift the speaker upward from the back cover and place it near the battery.
Lay device flat on the table.
Firmly grip the device on the edges. Take the wedge portion of the spudger tool and push in between the battery and the screen with force. Begin pushing the spudger with the wedge underneath the battery all the way around in order to break the glue.
Repeat this step pushing further across and underneath until the battery is loose.
이 단계에 사용된 도구:Tweezers$4.99
First orient the device to a portrait position as seen in the picture.
Locate the zero insertion force (ZIF) connector shown in the figure.
Use the tweezers to pull up on the zero insertion force (ZIF) connector and release the ribbon.
Next, take the tweezers and grab the ribbon and pull outward from the socket.
