주요 콘텐츠로 건너뛰기
DigiTech RP70 DC Power Connector Replacement
필요한 것
  1. DigiTech RP70 DC Power Connector Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 DigiTech RP70 DC Power Connector Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 DC Power Connector Replacement: 2 단계, 이미지 2개 중 1개 DigiTech RP70 DC Power Connector Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 DC Power Connector Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 DC Power Connector Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70 DC Power Connector Replacement, DC Power Connector: 5 단계, 이미지 1개 중 1개
    • Desolder the back of the motherboard where the power connector is located.
결론
작성자
4다른 기여자 명과 함께
Elijah Smith
회원 가입일: 09/10/18
738 평판
안내서 6개를 작성함
1가이드 댓글
Later? I cant see to other
ISAAC SALAZAR - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 8
전체 시간: 434
