소개
Speaker volume is low or audio is distorted are symptoms of a faulty speaker. Please review our troubleshooting page Digiland 10.1'' DL1016 Troubleshooting before proceeding to the replacement. Once you have determined your symptoms and are certain you need a speaker replacement, continue on with this guide.
This guide will help you replace the speaker of a Digiland 10.1” DL1016 device
필요한 것
1 단계 Digiland 10.1'' DL1016 Remove Backing
주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
4 단계 Digiland 10.1'' DL1016 Remove Battery
주의: 4 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
The speakers are marked in red.
Disconnect the speaker connections.
Remove the speakers.
