주요 콘텐츠로 건너뛰기
소개
This guide will be showing you how to replace the charging port for the Digital2 D2-861G model. Be sure to carefully remove parts to avoid damaging the device.
부품
지정된 부품이 없습니다.
  1. Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Place your device on a soft cloth to avoid scratching the screen.
    • Flip your device over so back panel is facing upwards.
  2. Do not use a lot of force as it can break the clips or the back panel.
    • Do not use a lot of force as it can break the clips or the back panel.
    • Insert spudger in the slot below the micro SD card.
    • You should hear clips releasing as you pry along the edges.
    • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
  3. Locate the gold colored ZIF (Zero insertion force) connector and disconnect it from the motherboard. To disconnect the ZIF connector, go under the black tab and lift up. Then pull the connector out. Locate the bundled cable connector and disconnect it by simply pulling it gently or using a spudger.
    • Locate the gold colored ZIF (Zero insertion force) connector and disconnect it from the motherboard.
    • To disconnect the ZIF connector, go under the black tab and lift up. Then pull the connector out.
    • Locate the bundled cable connector and disconnect it by simply pulling it gently or using a spudger.
    • Disconnecting the bundled cable connector helps avoid short circuiting anything on the device.
  4. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  5. Make sure to have your magnetic board to hold your screws. Remove two 3.51mm screws that are located on the top corners with your Phillips #00 screwdriver. Next, unplug the ZIF connector by going under the black tab and simply lift up.
    • Make sure to have your magnetic board to hold your screws.
    • Remove two 3.51mm screws that are located on the top corners with your Phillips #00 screwdriver.
    • Next, unplug the ZIF connector by going under the black tab and simply lift up.
    • Slide the connector out with the pointed side of the spudger.
  6. This step is optional if you want to remove the metal casing. Insert the pointed side of the spudger in the corner and gently lift. Once one side is lifted, use your fingers and with little force, lift up to remove the case.
    • This step is optional if you want to remove the metal casing.
    • Insert the pointed side of the spudger in the corner and gently lift.
    • Once one side is lifted, use your fingers and with little force, lift up to remove the case.
  7. Use little force or else you risk breaking the motherboard.
    • Use little force or else you risk breaking the motherboard.
    • Watch out for the ZIF connector!
    • There is a white clip holding the motherboard.
    • To remove the motherboard, grab the component on the top left and gently lift while pushing or pulling to the right.
  8. Refer to iFixit's guide on how to Solder How To Solder and Desolder Connections
결론
Eduardo Duran
회원 가입일: 2016년 09월 29일
600 평판
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
전체 시간: 157
