주요 콘텐츠로 건너뛰기
Digital2 D2-912 Speaker Replacement
필요한 것
  1. Digital2 D2-912 Speaker Replacement, External Cover: 1 단계, 이미지 1/1
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Speaker Replacement: 2 단계, 이미지 1/2 Digital2 D2-912 Speaker Replacement: 2 단계, 이미지 2/2
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Pull the speaker away from the tablet. It should easily come off, as it is held on with a magnet.
  4. Digital2 D2-912 Speaker Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    구매
    • Remove the wires from the motherboard using a soldering iron and a solder sucker.
    • Refer to ifixit's soldering guide to remove the solder on the wires.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lindsay Richardson
회원 가입일: 09/16/15
394 평판
안내서 3개 작성하였습니다
IUPUI, Team 1-1, Harley Fall 2015 IUPUI, Team 1-1, Harley Fall 2015 회원
IUPUI-HARLEY-F15S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 142
