주요 콘텐츠로 건너뛰기
Digital2 Platinum Pad 9 Battery Replacement
필요한 것
  1. Digital2 Platinum Pad 9 Battery Replacement, External Cover: 1 단계, 이미지 1/1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Battery Replacement: 2 단계, 이미지 1/2 Digital2 Platinum Pad 9 Battery Replacement: 2 단계, 이미지 2/2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Battery Replacement: 3 단계, 이미지 1/2 Digital2 Platinum Pad 9 Battery Replacement: 3 단계, 이미지 2/2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Battery Replacement, Battery: 4 단계, 이미지 1/1
    • The battery is the bigger square object in the center of the device held down by 3 pieces of yellow tape.
  5. Digital2 Platinum Pad 9 Battery Replacement: 5 단계, 이미지 1/1
    • Carefully remove the tape that is holding down the battery.
  6. Digital2 Platinum Pad 9 Battery Replacement: 6 단계, 이미지 1/2 Digital2 Platinum Pad 9 Battery Replacement: 6 단계, 이미지 2/2
    • Lift up the battery it will be glued to the device.
    • Be sure to gently work it to loosen and remove so that you do not damage your device.
  7. Digital2 Platinum Pad 9 Battery Replacement: 7 단계, 이미지 1/1
결론
David DeMeritt
회원 가입일: 03/08/16
637 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 5-6, Landers Spring 2016 UMass Dartmouth, Team 5-6, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G6
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Where can one buy the battery?
BedfordGlen Board - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 293
