주요 콘텐츠로 건너뛰기
Dirt Devil Scorpion Quick Flip Motor Replacement
필요한 것
  1. Dirt Devil Scorpion Quick Flip Motor Replacement, Motor: 1 단계, 이미지 1/1
    • Gently remove filter adapter from the vacuum body by pressing the gray plastic release button.
  2. Dirt Devil Scorpion Quick Flip Motor Replacement: 2 단계, 이미지 1/1
    • Place the vacuum body on its left side and remove all 4mm screws with a Phillips #1 screwdriver.
  3. Dirt Devil Scorpion Quick Flip Motor Replacement: 3 단계, 이미지 1/1
    • Carefully take apart the shell of the vacuum body.
    • Cut the two wires attached to the motor and remove the motor from the body.
  4. Dirt Devil Scorpion Quick Flip Motor Replacement: 4 단계, 이미지 1/1
    • Solder the wires from the replacement motor to the wires connecting it to the power cord.
    • Carefully place the replacement motor back into its correct position in the vacuum body.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
결론
Adam Mooney
회원 가입일: 10/02/19
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 23
전체 시간: 497
