소개
The motor on the Dirt Devil Scorpion Quick Flip has been reported to slow down and not operate at its maximum level over time. These symptoms point to an issue with the motor, which is responsible for providing the suction forces allowing the vacuum to work. This guide will demonstrate how to replace the motor in this device. This guide will require soldering, so check out our How to Solder and Desolder Connections guide if you are unfamiliar with the process.
필요한 것
Gently remove filter adapter from the vacuum body by pressing the gray plastic release button.
