주요 콘텐츠로 건너뛰기
Dirt Devil Scorpion Quick Flip Power Cord Replacement
필요한 것
  1. Dirt Devil Scorpion Quick Flip Power Cord Replacement, Power Cord: 1 단계, 이미지 1/1
    • While holding the device by the handle, press the button on the left-hand side of the vacuum handle in order to release the nozzle from the body.
  2. Dirt Devil Scorpion Quick Flip Power Cord Replacement: 2 단계, 이미지 1/2 Dirt Devil Scorpion Quick Flip Power Cord Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 Screwdriver, remove all six of the 4 mm screws holding the shell together.
  3. Dirt Devil Scorpion Quick Flip Power Cord Replacement: 3 단계, 이미지 1/1
    • Using utility scissors, cut the black and white cables approximately an inch and a half above where they connect to the faulty power cord.
  4. Dirt Devil Scorpion Quick Flip Power Cord Replacement: 4 단계, 이미지 1/1
    • Using a soldering iron, fuse the black and white cables from the new power cord to where the previous cord was cut away.
    • Using electrical tape, cover the exposed area.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
결론
Corbet E Warren
회원 가입일: 10/02/19
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 15
전체 시간: 293
