주요 콘텐츠로 건너뛰기
Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case
필요한 것
  1. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: 1 단계, 이미지 2개 중 1개 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: 1 단계, 이미지 2개 중 2개
    • Turn the speaker face down, so the connector side is up.
    • Remove the four #2 Philips screws on the back plate.
  2. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 2 단계, 이미지 1개 중 1개
    • Remove the foam insert to expose the two spade connectors.
    • Carefully separate the connectors
  3. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 3 단계, 이미지 2개 중 1개 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 3 단계, 이미지 2개 중 2개
    • Turn the speaker so the grill side is up.
    • Remove the four screws on the grill. I had to use a t-10 Torx bit to remove them.
    • The grill is not glued on, but may require a bit of prying to remove.
  4. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 4 단계, 이미지 2개 중 1개 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 4 단계, 이미지 2개 중 2개
    • Remove the four silver bolts holding the speaker in place. These bolts also have threads inset for the grill screws to fit into.
    • This is a pretty quick and easy teardown, not too many parts in this one. The meyer speaker's part number is ST-164. It's a 16 Ohm driver.
결론
다른 5명이 해당 안내서를 완성하였습니다.
RoggeSound
회원 가입일: 06/05/10
2,417 평판
안내서 1개를 작성함
2가이드 댓글
So I took one of my MM-4 apart because something was rattling. Turns out it has a loose magnet assembly. It must have been dropped in shipping.
Garrett McWilliams - 답글
Do you by any chance still have it?
I have two of them already and with some zipties and rubber they sound great again…
Would you by any chance ship the broken driver over to me?
Jan Marius -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 22
전체 시간: 7,214
