이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
it's a cheap low-end Music Phone
mine got wet so i decided to clean it up and look inside!
Flip it and pull the tab
the metal part should jump right off
after that remove the battery and sim card
i tried to remove the side panels but that didn't work so i tried on top and it did work (Jimmy worked fine)
after you unclip it you get that piece
remove these 2 TR6 Screws (mine were a bit blue)
open it up (clips on the bottom)
Remove the 4 TR6 Screws
remove the whole PCB and remove the clips from the display and it should pop off
2 of those fell of and i have NO idea where from (and i don't even care)
i cleaned it up and powered it up and it works (just make sure you don't short anything)
다른 9명이 해당 안내서를 완성하였습니다.
