주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
부품
지정된 부품이 없습니다.
  1. Use a large plastic opening tool along the rear panel: There are 4 clips to release. There are 4 clips to release.
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Slide the cover along the plastic frame. Slide the cover along the plastic frame.
    • Slide the cover along the plastic frame.
  3. Slide off the largest plastic pieces.
    • Slide off the largest plastic pieces.
  4. Bend the second small plastic piece to release it from the rubber piece. Now you can slide it out. Now you can slide it out.
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
결론
Gaetan
회원 가입일: 2012년 12월 26일
9,568 평판
안내서 18개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 940
