주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Disassembling Western Digital Essentials HD LED Light conducting plastic pieces
필요한 것
  1. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: 1 단계, 이미지 1/3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: 1 단계, 이미지 2/3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: 1 단계, 이미지 3/3
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: 2 단계, 이미지 1/2 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: 2 단계, 이미지 2/2
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, LED Light conducting plastic pieces: 3 단계, 이미지 1/1
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: 4 단계, 이미지 1/3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: 4 단계, 이미지 2/3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: 4 단계, 이미지 3/3
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
결론
Gaetan
회원 가입일: 12/26/12
9,574 평판
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 14
전체 시간: 1,090
