주요 콘텐츠로 건너뛰기
Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard
필요한 것
  1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: 1 단계, 이미지 1/3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: 1 단계, 이미지 2/3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: 1 단계, 이미지 3/3
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 2 단계, 이미지 1/2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 2 단계, 이미지 2/2
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, LED Light conducting plastic pieces: 3 단계, 이미지 1/1
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 4 단계, 이미지 1/3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 4 단계, 이미지 2/3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 4 단계, 이미지 3/3
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  5. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: 5 단계, 이미지 1/2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: 5 단계, 이미지 2/2
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  6. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 6 단계, 이미지 1/2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 6 단계, 이미지 2/2
    • Remove the 4 rubber piece from the plastic frame at each corner.
  7. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 7 단계, 이미지 1/1
    • Remove the rubber piece from the SATA/USB bridge logic board.
  8. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: 8 단계, 이미지 1/2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: 8 단계, 이미지 2/2
    • Remove both screws holding the retaining plate and the hard drive.
    • Slide the retaining plate in order to disconnect the SATA connector.
  9. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: 9 단계, 이미지 1/1
    • Remove both screws holding the retaining plate with the logic board.
결론
Gaetan
회원 가입일: 12/26/12
9,574 평판
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 21
전체 시간: 2,010
