소개
To replace the battery, you will very likely need a soldering iron and solder. Model number 9854L has the battery soldered to the + and - terminals.
도구
부품
지정된 부품이 없습니다.
Begin by removing the rubber grip along the handle.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 3개
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful. Thank you so much
