주요 콘텐츠로 건너뛰기
Disconnecting Microphone from Logitech Pro 9000 Motherboard
필요한 것
  1. Disconnecting Microphone from Logitech Pro 9000 Motherboard, Front and Back Cover: 1 단계, 이미지 2개 중 1개 Disconnecting Microphone from Logitech Pro 9000 Motherboard, Front and Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Disconnecting Microphone from Logitech Pro 9000 Motherboard: 2 단계, 이미지 2개 중 1개 Disconnecting Microphone from Logitech Pro 9000 Motherboard: 2 단계, 이미지 2개 중 2개
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Disconnecting Microphone from Logitech Pro 9000 Motherboard, Microphone Connection: 3 단계, 이미지 2개 중 1개 Disconnecting Microphone from Logitech Pro 9000 Motherboard, Microphone Connection: 3 단계, 이미지 2개 중 2개
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
결론
작성자
6다른 기여자 명과 함께
Timothy Forrest
회원 가입일: 04/18/13
19 평판
안내서 2개를 작성함
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G34
4 회원들
안내서 16개를 작성함
1가이드 댓글
This guide doesn’t show a motherboard and is a copy of this other guide (for a webcam):
Logitech Webcam Pro 9000 Microphone Replacement
Maximilian Cohan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 1,977
