주요 콘텐츠로 건너뛰기
Dismountable Hand Blender
필요한 것
  1. Dismountable Hand Blender, Dismountable Hand Blender: 1 단계, 이미지 1/1
    • Finding and fixing the problem is a cinch!
    • Disassembling the mixer is very destructive!
    • This appliance is a clear example of planned obsolescence since a worn (carbon) brush makes it fit for the trash.
    • If the fault is in the electronic module, clever cutting can make an acceptable repair possible as shown in this ElectroMax video.
  2. Dismountable Hand Blender: 2 단계, 이미지 1/3 Dismountable Hand Blender: 2 단계, 이미지 2/3 Dismountable Hand Blender: 2 단계, 이미지 3/3
    • The speed control knob is easy to disassemble by inserting a knife blade under the graduated circle and prying it up.
    • There are three obstacles to the removal of the motor and electronics module from this mixer:
    • The entire motor block enclosure is firmly secured with adhesive.
    • This motor bearing fastener acts as a circular mount.
    • This plunger system fastener is a second circular mount.
    • I do not see a way around any of these three issues without a certain amount of "destruction".
  3. Dismountable Hand Blender: 3 단계, 이미지 1/1
    • One of the two leads has broken off. Possibly made fragile by improper assembly?
    • Correctly resoldering the lead lets the motor operate normally again.
결론
We do need to cut the shell off the mixer, which makes salvaging this part difficult.
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Louis Possoz
회원 가입일: 01/10/15
435 평판
안내서 3개 작성하였습니다
Repair Café Louvain-la-Neuve Repair Café Louvain-la-Neuve 회원
Local Repair Groups
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
pourquoi acheter du matériel pro si on ne peut pas le réparer
laurencedelanoue - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 77
30일 전: 273
전체 시간: 14,308
