주요 콘텐츠로 건너뛰기
Door Mirror Replacement
필요한 것
  1. Door Mirror Replacement, Door Mirror: 1 단계, 이미지 1개 중 1개
    • Use a screwdriver to remove the two brackets securing the top of the mirror.
    • The mirror will fall forward once the two top brackets are released; be sure to support the mirror as you unscrew the brackets.
    • The type of screwdriver needed will depend on your specific brackets.
  2. Door Mirror Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the broken mirror off of the door.
    • Remove any cardboard or other cushioning (if any) from the door.
  3. Door Mirror Replacement: 3 단계, 이미지 1개 중 1개
    • Loosen, but don't remove, the bottom brackets to accommodate the width of the new mirror.
  4. Door Mirror Replacement: 4 단계, 이미지 1개 중 1개
    • If you have new mirror supports, then remove the old brackets entirely and replace them with the new brackets.
  5. Door Mirror Replacement: 5 단계, 이미지 1개 중 1개
    • Replace any cushioning behind the mirror.
    • While supporting the top of the mirror, set the mirror into the bottom brackets, then tighten the brackets.
  6. Door Mirror Replacement: 6 단계, 이미지 1개 중 1개
    • Replace the top brackets and tighten them to full secure the mirror.
결론
Enjoy your new mirror!
작성자
5다른 기여자 명과 함께
Seth Wanderman
회원 가입일: 02/28/22
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 29
전체 시간: 935
