주요 콘텐츠로 건너뛰기
Dragon Touch A1x Plus Battery Replacement
필요한 것
  1. Dragon Touch A1x Plus Battery  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Battery  Replacement: 2 단계, 이미지 2개 중 1개 Dragon Touch A1x Plus Battery  Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Battery  Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Battery  Replacement: 4 단계, 이미지 1개 중 1개
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Battery  Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Battery  Replacement: 6 단계, 이미지 2개 중 1개 Dragon Touch A1x Plus Battery  Replacement: 6 단계, 이미지 2개 중 2개
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
결론
작성자
3다른 기여자 명과 함께
Josh Null
회원 가입일: 03/21/18
313 평판
안내서 3개를 작성함
IUPUI, Team S5-G5, Baechle Spring 2018 IUPUI, Team S5-G5, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S5G5
3 회원들
안내서 6개를 작성함
1가이드 댓글
where can you find a replacement battery for this tablet?
Lupe Rdrgz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 16
전체 시간: 2,057
