주요 콘텐츠로 건너뛰기
Dragon Touch Y88X Plus Motherboard Replacement
필요한 것
  1. Dragon Touch Y88X Plus Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove any adhesive strips keeping wires in place.
  3. Dragon Touch Y88X Plus Motherboard Replacement: 3 단계, 이미지 1/1
    • Desolder the wires connected to the motherboard to disconnect the battery and speaker.
  4. Dragon Touch Y88X Plus Motherboard Replacement: 4 단계, 이미지 1/2 Dragon Touch Y88X Plus Motherboard Replacement: 4 단계, 이미지 2/2
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three ZIF connectors.
    • Be sure to pry up on the hinged flap, not the connector socket.
    • Use a spudger to slide the ribbon cables from the connectors.
  5. Dragon Touch Y88X Plus Motherboard Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the edges of the motherboard.
  6. Dragon Touch Y88X Plus Motherboard Replacement: 6 단계, 이미지 1/1
    • Gently lift the motherboard from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Cody Camara
회원 가입일: 11/01/23
149 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-4, Petersen Fall 2023 UMass Dartmouth, Team 1-4, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 74
