주요 콘텐츠로 건너뛰기
Draining a Toilet Tank
  1. Draining a Toilet Tank, Tank Lid: 1 단계, 이미지 1/3 Draining a Toilet Tank, Tank Lid: 1 단계, 이미지 2/3 Draining a Toilet Tank, Tank Lid: 1 단계, 이미지 3/3
    • Lift the tank lid up and away from the toilet tank.
  2. Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: 2 단계, 이미지 1/2 Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: 2 단계, 이미지 2/2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Draining a Toilet Tank, Draining a Toilet Tank: 3 단계, 이미지 1/2 Draining a Toilet Tank, Draining a Toilet Tank: 3 단계, 이미지 2/2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
결론
Most toilets retain a small amount of water in the tank after draining. To remove any excess water from the bottom of your toilet tank, use our guide for Sponge Drying a Toilet Tank.
다른 한 분이 해당 안내서를 완성하였습니다.
Ron Davis
회원 가입일: 02/17/15
31,391 평판
안내서 13개 작성하였습니다
댓글 2개
I have a cracking in my toilet tank going almost the length of the tank and below water line resulting in a leak. In your experience is a sealant a good option or in reality would the tank need to be replaced in time ?
Thanks
K EVANS - 답글
It would make more sense to replace the tank, than seal any crack which would only reappear after time anyway.
John Turner -
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 42
30일 전: 191
전체 시간: 32,791
