소개
Most gravity flush toilets retain a small amount of water in the tank after draining. If there is still water in the bottom of your toilet tank after following our Draining a Toilet Tank guide, you may need to remove the excess water with a sponge.
도구
부품
지정된 부품이 없습니다.
Use a sponge to soak up and remove any remaining water from the toilet tank.
Periodically squeeze the excess water from the sponge.
거의 끝나갑니다!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
