주요 콘텐츠로 건너뛰기
Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement
필요한 것
  1. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Battery: 1 단계, 이미지 1/3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Battery: 1 단계, 이미지 2/3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Battery: 1 단계, 이미지 3/3
    • Pull back on the release tabs to disconnect the battery pack from the housing.
    • When installing a new battery, you may need to charge it before using it.
  2. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Motor-Shaft Assembly: 2 단계, 이미지 1/3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Motor-Shaft Assembly: 2 단계, 이미지 2/3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Motor-Shaft Assembly: 2 단계, 이미지 3/3
    • Remove the two screws from the back of the device with the TR10 Torx Security screwdriver.
    • Make sure you have removed the battery before proceeding as accidentally powering-on the device while disassembling is dangerous due to the high-speed components inside.
  3. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: 3 단계, 이미지 1/3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: 3 단계, 이미지 2/3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: 3 단계, 이미지 3/3
    • Lift off the unscrewed plastic cover at an angle, away from the tip of the device.
    • Gently lift the cover. It won't take much force to remove it.
  4. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: 4 단계, 이미지 1/3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: 4 단계, 이미지 2/3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: 4 단계, 이미지 3/3
    • Lift the tip of the motor-shaft assembly gently, then pull the assembly out.
    • The blue battery contact and the spring for the shaft lock button may pop out when you remove the motor-shaft assembly. Make sure to keep track of these pieces, as they are very small.
  5. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Shaft Lock Assembly: 5 단계, 이미지 1/1
    • There are two pieces that make up the shaft lock assembly:
    • The key.
    • The wire ring.
    • The key holds the wire ring in place, and the wire ring secures the motor shaft.
  6. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: 6 단계, 이미지 1/3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: 6 단계, 이미지 2/3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: 6 단계, 이미지 3/3
    • Remove the wire ring from the device.
    • The wire ring may have come out when the motor-shaft assembly was removed.
    • Remove the key from its slot.
  7. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: 7 단계, 이미지 1/2 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: 7 단계, 이미지 2/2
    • Ensure that the shaft lock assembly fits together properly when reassembling the device.
    • The notch in the wire ring should fit on the key as pictured.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kat
회원 가입일: 02/10/16
840 평판
안내서 3개 작성하였습니다
USF Tampa, Team 3-4, Sullivan Spring 2016 USF Tampa, Team 3-4, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S3G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 1,814
