주요 콘텐츠로 건너뛰기
Drill Master Heat Gun Power Switch Replacement
필요한 것
  1. Drill Master Heat Gun Power Switch Replacement, Power Switch: 1 단계, 이미지 1/1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Power Switch Replacement: 2 단계, 이미지 1/1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Power Switch Replacement: 3 단계, 이미지 1/3 Drill Master Heat Gun Power Switch Replacement: 3 단계, 이미지 2/3 Drill Master Heat Gun Power Switch Replacement: 3 단계, 이미지 3/3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Power Switch Replacement: 4 단계, 이미지 1/1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Power Switch Replacement: 5 단계, 이미지 1/1
    • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
    • Screws do not come out of connector.
  6. Drill Master Heat Gun Power Switch Replacement: 6 단계, 이미지 1/1
    • Squeeze the tabs on either side of the power switch to remove from the casing.
  7. Drill Master Heat Gun Power Switch Replacement: 7 단계, 이미지 1/2 Drill Master Heat Gun Power Switch Replacement: 7 단계, 이미지 2/2
    • Remove the black, plastic wire protectors from the end of the power switch.
  8. Drill Master Heat Gun Power Switch Replacement: 8 단계, 이미지 1/1
    • Use soldering iron to remove the electrical wiring from the power switch. To replace the power switch, solder the new switch onto the wires.
    • Heating the soldering metal will allow you to pull off the electrical wiring.
    • For a brush-up on proper soldering, check out How to Solder and Desolder Connections.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mikayla Kim
회원 가입일: 01/31/17
523 평판
안내서 5개 작성하였습니다
University of North Texas, Team 1-2, Campbell Spring 2017 University of North Texas, Team 1-2, Campbell Spring 2017 회원
UNT-CAMPBELL-S17S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 2,852
