주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Droid Ultra XT1080 Battery Replacement
필요한 것
  1. Droid Ultra XT1080 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the SIM card tray from the side of the device using a plastic opening tool.
    댓글 쓰기
  2. Droid Ultra XT1080 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • After properly removing the SIM card tray take your spudger and press it in between the plastic case and the frame of the device until you hear a snap.
    • Work your way from the top and the other side to confirm all the clips are disconnected.
    • Be gentle when performing this so you don't crack or break the plastic.
    댓글 쓰기
  3. Droid Ultra XT1080 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
    댓글 쓰기
  4. Droid Ultra XT1080 Battery Replacement: 4 단계, 이미지 2개 중 1개 Droid Ultra XT1080 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • After the top and bottom screws are removed remove the top and bottom plastic pieces that were secured to the device.
    댓글 쓰기
  5. Droid Ultra XT1080 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Begin to gently pry up the battery from the frame with a plastic opening tool to release it from its adhesive securing.
    댓글 쓰기
  6. Droid Ultra XT1080 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four T5 Torx screws securing the motherboard.
    댓글 쓰기
  7. Droid Ultra XT1080 Battery Replacement: 7 단계, 이미지 2개 중 1개 Droid Ultra XT1080 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Gently pry the motherboard out of the frame using the nylon spudger.
    • Make sure not to damage the LCD cable in the process.
    댓글 쓰기
  8. Droid Ultra XT1080 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the LCD cable with a spudger from the motherboard by gently lifting up the two connectors.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
knoyes
회원 가입일: 10/30/18
785 평판
안내서 5개를 작성함
UMass Dartmouth, Team S3-G8, Peak Fall 2018 UMass Dartmouth, Team S3-G8, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G8
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 46
전체 시간: 3,429
