주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DualShock 3 Battery Replacement
필요한 것
  1. DualShock 3 Battery Replacement, Rear Cover: 1 단계, 이미지 1개 중 1개
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
  2. DualShock 3 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
  3. DualShock 3 Battery Replacement: 3 단계, 이미지 2개 중 1개 DualShock 3 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
  4. DualShock 3 Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Lift the battery off the motherboard for enough clearance to access the battery connector.
  5. DualShock 3 Battery Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Carefully pull the battery connector away from its socket on the motherboard.
    • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
결론
다른 168명이 해당 안내서를 완성하였습니다.
20가이드 댓글
I got the shell separated but unfortunately snapped the lil plastic clip on the rear of the controller's bottom half. a lil super glue and treezers fixed tht up nicely...Thanks for the help
KUDOS to you!!!
Rob (rjmat42)
Robert - 답글 공유
I have different battery on my second controller, battery itself have pins to connect it with board, no more white plastic holder :/
Raf - 답글 공유
Try Amazon Cody
linzikerner - 답글 공유
whats is amazon cody?
Albert Einstein - 답글 공유
Anyone have any idea where I can find the plastic retainers for the battery? I bought the new one, but my old battery has the clips attached. I don't want this thing just jiggling around in there, it'll drive me nuts.
Thanks.
geoquin4 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 31
지난 7일: 301
지난 30일: 1,404
전체 시간: 231,740
