주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DualShock 3 Trigger Buttons Replacement
필요한 것
  1. DualShock 3 Trigger Buttons Replacement, Rear Cover: 1 단계, 이미지 1개 중 1개
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
    댓글 쓰기
  2. DualShock 3 Trigger Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
    댓글 쓰기
  3. DualShock 3 Trigger Buttons Replacement: 3 단계, 이미지 2개 중 1개 DualShock 3 Trigger Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
    댓글 쓰기
  4. DualShock 3 Trigger Buttons Replacement, Trigger Buttons: 4 단계, 이미지 1개 중 1개
    • While holding the black plastic trigger retainer with one hand, pull the #2 trigger off of its axle.
    댓글 쓰기
  5. DualShock 3 Trigger Buttons Replacement: 5 단계, 이미지 2개 중 1개 DualShock 3 Trigger Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • When reinstalling the #2 trigger, be sure the spring is positioned as shown before popping the axle back into place.
    댓글 쓰기
  6. DualShock 3 Trigger Buttons Replacement: 6 단계, 이미지 2개 중 1개 DualShock 3 Trigger Buttons Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the black plastic trigger retainer slightly away from the front cover.
    • Pull the #1 button out of the front cover.
    댓글 쓰기
  7. DualShock 3 Trigger Buttons Replacement: 7 단계, 이미지 2개 중 1개 DualShock 3 Trigger Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • Before sliding the trigger button retainer back into the rails molded into the front cover, be sure that the cylindrical post attached to the #1 button is sitting flat on the green rubber electronic switch cover. Failure to do so may lead to problems with fit during reassembly, and may cause the controller to not recognize inputs from the #1 button during operation.
    • The trigger button assembly is properly installed when the lip on the trigger button retainer sits flat against the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 78명이 해당 안내서를 완성하였습니다.
9가이드 댓글
Might want to add that there's a small catch/tab in the middle of the bottom of the controller that needs to be released when taking apart the covers.
This worked great, and also works on normal Sixaxis controllers. I used this to swap the broken spring from the L2 button on my DS3 for a good spring from my Sixaxis. Works like new now.
Will Foss - 답글 공유
The little green eletronic ribben where is it supposed to go?
dmall - 답글 공유
The #00 screwdriver is working better
Leopold287 - 답글 공유
Did you replace button 2 rod with plastic replacement part or use original rod piece when fixing button 2
Sidney Klemkosky - 답글 공유
Is there a way I can buy trigger retainers?
CynicalSheep - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 46
지난 7일: 350
지난 30일: 1,280
전체 시간: 140,563
