주요 콘텐츠로 건너뛰기
DualShock 3 Battery Replacement
필요한 것
  1. DualShock 3 Battery Replacement, Step 1: 1 단계, 이미지 3개 중 1개 DualShock 3 Battery Replacement, Step 1: 1 단계, 이미지 3개 중 2개 DualShock 3 Battery Replacement, Step 1: 1 단계, 이미지 3개 중 3개
    • This is the Dualshock 3 controller
    • On the back of the controller, there will be five 7.2mm Phillips screws securing the body of the controller. (The five screws are circled in black.)
    • Remove each of the five screws from the back of the DualShock controller.
  2. DualShock 3 Battery Replacement, Step 2: 2 단계, 이미지 1개 중 1개
    • Push the center of the rear cover (between the two analog sticks) and carefully lift the lower edge away from the rest of the controller.
  3. DualShock 3 Battery Replacement, Step 3: 3 단계, 이미지 1개 중 1개
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, but be careful so that you won't pop off the #2 triggers.
    • Here is a DualShock trigger guide on the IFIXIT website in case you need to reattach the #2 triggers.
  4. DualShock 3 Battery Replacement, Step 4: 4 단계, 이미지 1개 중 1개
    • Move the battery off the motherboard so you have enough clearance to access the battery connector.
  5. DualShock 3 Battery Replacement, Step 5: 5 단계, 이미지 2개 중 1개 DualShock 3 Battery Replacement, Step 5: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Carefully pull the battery connector away from the socket that is attached to the motherboard. ( Battery connector is circled in black.)
    • It may be safer to use a tool like tweezers or pliers to pull the battery connector out of the socket.
    • Now you can dispose of the old battery safely. For example taking old used batteries to a household hazardous waste facility.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Marcus Aiken
회원 가입일: 11/08/16
214 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 28
지난 30일: 173
전체 시간: 4,154
