이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the plastic trigger buttons. The #2 trigger button has an attached internal spring.
필요한 것
Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
While holding the black plastic trigger retainer with one hand, pull the #2 trigger off of its axle.
다른 69명이 해당 안내서를 완성하였습니다.
댓글 8개
Might want to add that there's a small catch/tab in the middle of the bottom of the controller that needs to be released when taking apart the covers.
This worked great, and also works on normal Sixaxis controllers. I used this to swap the broken spring from the L2 button on my DS3 for a good spring from my Sixaxis. Works like new now.
The #00 screwdriver is working better
Leopold287 - 답글
Did you replace button 2 rod with plastic replacement part or use original rod piece when fixing button 2
Is there a way I can buy trigger retainers?
