주요 콘텐츠로 건너뛰기
DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement
필요한 것
  1. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Check your controller model: 1 단계, 이미지 1/1
    • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
    • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
  2. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unfasten the rear case: 2 단계, 이미지 1/2 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unfasten the rear case: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
  3. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the L1 button: 3 단계, 이미지 1/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the L1 button: 3 단계, 이미지 2/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the L1 button: 3 단계, 이미지 3/3
    • Use an opening pick to pry each corner of the L1 button from the front case.
    • Cover the button to prevent it from ejecting out of your workspace.
    • Remove the button.
  4. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the R1 button: 4 단계, 이미지 1/1
    • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
  5. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unclip the rear case: 5 단계, 이미지 1/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unclip the rear case: 5 단계, 이미지 2/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unclip the rear case: 5 단계, 이미지 3/3
    • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
    • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
    • Slide your pick toward the handle and pry up to release the first clip.
    • Repeat this procedure on the other side of the controller to release the second clip.
  6. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 6 단계, 이미지 1/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 6 단계, 이미지 2/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 6 단계, 이미지 3/3
    • Two more clips secure the rear case near the extension port and the headphone jack.
    • Insert your opening pick between the front case and rear case at either side of the ports.
    • Twist your pick to unclip this section of the rear case from the front case.
    • If the rear case feels stuck, insert and twist your pick from different angles.
    • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
  7. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 7 단계, 이미지 1/1
    • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
    • Locate the clips by looking through the gap above the R2 or L2 buttons.
  8. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 8 단계, 이미지 1/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 8 단계, 이미지 2/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 8 단계, 이미지 3/3
    • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
    • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
    • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
    • Repeat this procedure for the clip near the L2 button.
  9. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the rear case: 9 단계, 이미지 1/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the rear case: 9 단계, 이미지 2/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the rear case: 9 단계, 이미지 3/3
    • Press the R2 button and slide the rear case over it.
  10. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 10 단계, 이미지 1/1
    • Press the L2 button and slide the rear case over it.
  11. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 11 단계, 이미지 1/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 11 단계, 이미지 2/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 11 단계, 이미지 3/3
    • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
  12. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the interconnect cable: 12 단계, 이미지 1/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the interconnect cable: 12 단계, 이미지 2/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the interconnect cable: 12 단계, 이미지 3/3
    • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
    • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
  13. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the battery: 13 단계, 이미지 1/2 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the battery: 13 단계, 이미지 2/2
    • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
    • Only pull on the head of the connector—don't pull on the cable itself.
  14. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the battery: 14 단계, 이미지 1/1
    • Remove the battery.
  15. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the reset button extension: 15 단계, 이미지 1/2 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the reset button extension: 15 단계, 이미지 2/2
    • Grab and remove the reset button extension from its recess in the battery bracket.
  16. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the battery bracket: 16 단계, 이미지 1/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the battery bracket: 16 단계, 이미지 2/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the battery bracket: 16 단계, 이미지 3/3
    • Locate the two clips securing the battery bracket to the motherboard.
    • Insert the point of your spudger into the opening behind the right bracket clip.
    • Depress the clip to disengage it from the motherboard.
    • Lift up the right edge of the battery bracket.
  17. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 17 단계, 이미지 1/2 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement: 17 단계, 이미지 2/2
    • Insert the point of your spudger in the opening behind the left bracket clip.
    • Remove the battery bracket.
  18. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the touch pad: 18 단계, 이미지 1/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the touch pad: 18 단계, 이미지 2/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Disconnect the touch pad: 18 단계, 이미지 3/3
    • Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
    • Use tweezers or your fingers to disconnect the cable using its blue pull tab.
  19. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Unfasten the motherboard: 19 단계, 이미지 1/1
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
  20. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the motherboard: 20 단계, 이미지 1/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the motherboard: 20 단계, 이미지 2/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the motherboard: 20 단계, 이미지 3/3
    • Be careful not to strain the vibration motor cables. Follow this guide to re-solder the vibration motors if they break off the motherboard.
    • Lift the motherboard from the midframe.
    • Guide the analog stick covers through their cutouts in the front case.
    • Flip the motherboard over the bottom of the controller, leaving the vibration motor cables attached.
  21. DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the analog stick covers: 21 단계, 이미지 1/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the analog stick covers: 21 단계, 이미지 2/3 DualShock 4 (CUH-ZCT1U) Analog Stick Covers Replacement, Remove the analog stick covers: 21 단계, 이미지 3/3
    • Grab and pull the analog stick covers straight off their modules.
    • During reassembly, rotate and press the covers until they slide onto the modules.
결론
다른 133명이 해당 안내서를 완성하였습니다.
Clay Eickemeyer
회원 가입일: 09/19/22
66,438 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,818개 작성하였습니다
댓글 14개
So I followed all the steps, got the sticks in. But when I put the controller back together it Wouldent turn on. Do you guys have any clue as to what it could be?
blscott2270 - 답글
Same exact thing happened to me, just wouldn't turn back on
Andrew Purcell -
Me too and all the reconnected cables are connected correctly, but it just won’t work.
Andy Hui -
Hope you guys still keep the parts, since the problem can be resolved by following the post below successfully. :)
https://www.google.com.hk/amp/s/amp.redd...
Andy Hui -
i think you didn't put a wire in
Gabrys Holcman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 108
30일 전: 631
전체 시간: 140,355
