주요 콘텐츠로 건너뛰기
DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement
필요한 것
  1. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Check your controller model: 1 단계, 이미지 1개 중 1개
    • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
    • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
  2. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unfasten the rear case: 2 단계, 이미지 2개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unfasten the rear case: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
  3. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the L1 button: 3 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the L1 button: 3 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the L1 button: 3 단계, 이미지 3개 중 3개
    • Use an opening pick to pry each corner of the L1 button from the front case.
    • Cover the button to prevent it from ejecting out of your workspace.
    • Remove the button.
  4. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the R1 button: 4 단계, 이미지 1개 중 1개
    • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
  5. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unclip the rear case: 5 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unclip the rear case: 5 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unclip the rear case: 5 단계, 이미지 3개 중 3개
    • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
    • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
    • Slide your pick toward the handle and pry up to release the first clip.
    • Repeat this procedure on the other side of the controller to release the second clip.
  6. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 6 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 6 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 6 단계, 이미지 3개 중 3개
    • Two more clips secure the rear case near the extension port and the headphone jack.
    • Insert your opening pick between the front case and rear case at either side of the ports.
    • Twist your pick to unclip this section of the rear case from the front case.
    • If the rear case feels stuck, insert and twist your pick from different angles.
    • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
  7. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
    • Locate the clips by looking through the gap above the R2 or L2 buttons.
  8. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 8 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 8 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 8 단계, 이미지 3개 중 3개
    • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
    • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
    • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
    • Repeat this procedure for the clip near the L2 button.
  9. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the rear case: 9 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the rear case: 9 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the rear case: 9 단계, 이미지 3개 중 3개
    • Press the R2 button and slide the rear case over it.
  10. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 10 단계, 이미지 1개 중 1개
    • Press the L2 button and slide the rear case over it.
  11. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 11 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 11 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 11 단계, 이미지 3개 중 3개
    • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
  12. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the interconnect cable: 12 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the interconnect cable: 12 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the interconnect cable: 12 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
    • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
  13. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
    • Only pull on the head of the connector—don't pull on the cable itself.
  14. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the battery: 14 단계, 이미지 1개 중 1개
    • Remove the battery.
  15. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the reset button extension: 15 단계, 이미지 2개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the reset button extension: 15 단계, 이미지 2개 중 2개
    • Grab and remove the reset button extension from its recess in the battery bracket.
  16. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the battery bracket: 16 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the battery bracket: 16 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the battery bracket: 16 단계, 이미지 3개 중 3개
    • Locate the two clips securing the battery bracket to the motherboard.
    • Insert the point of your spudger into the opening behind the right bracket clip.
    • Depress the clip to disengage it from the motherboard.
    • Lift up the right edge of the battery bracket.
  17. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 17 단계, 이미지 2개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 17 단계, 이미지 2개 중 2개
    • Insert the point of your spudger in the opening behind the left bracket clip.
    • Remove the battery bracket.
  18. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the touch pad: 18 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the touch pad: 18 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the touch pad: 18 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
    • Use tweezers or your fingers to disconnect the cable using its blue pull tab.
  19. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unfasten the motherboard: 19 단계, 이미지 1개 중 1개
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
    • During reassembly, hold the motherboard tight to the front case before fastening it. Test each button to ensure the silicone button pads are properly aligned. If each button presses as expected, fasten the motherboard.
  20. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the midframe: 20 단계, 이미지 2개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the midframe: 20 단계, 이미지 2개 중 2개
    • Grab the midframe by its plastic protrusions or the vibration motors and remove it.
    • Be careful not to separate the motherboard from the midframe, as they're only connected to each other by the vibration motor cables.
    • During reassembly, take your time positioning the midframe. Use the alignment posts to help guide it into place, and make sure the touch pad cable doesn't become trapped underneath.
  21. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the motherboard: 21 단계, 이미지 2개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the motherboard: 21 단계, 이미지 2개 중 2개
    • Be careful not to strain the vibration motor cables. Follow this guide to re-solder the vibration motors if they break off the motherboard.
    • Lift the motherboard and flip it over the bottom of the midframe, leaving the vibration motor cables attached.
  22. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the R2 button: 22 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the R2 button: 22 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the R2 button: 22 단계, 이미지 3개 중 3개
    • Firmly grip the R2 button and unclip each peg from the midframe.
    • The spring may eject from the inside peg. Be careful not to lose it.
    • Remove the R2 button.
  23. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the L2 button: 23 단계, 이미지 1개 중 1개
    • Unclip the L2 button from the midframe and remove it, making sure not to lose the small spring from the inside peg.
  24. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Reassembly information: 24 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Reassembly information: 24 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Reassembly information: 24 단계, 이미지 3개 중 3개
    • During reassembly, follow these instructions to install the springs onto the R2 and L2 buttons:
    • Lay the midframe face-down and orient the button properly.
    • Place the spring over the inside peg with its bent ends facing upward.
    • Rest one end of the spring in its channel in the button.
    • Place the button over its clips and rest the other end of the spring in its channel in the midframe.
    • Press the button's pegs into their clips until they snap into place.
  25. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the silicone button pads: 25 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the silicone button pads: 25 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the silicone button pads: 25 단계, 이미지 3개 중 3개
    • Grab the upper edge of the R1 and R2 button pad.
    • Slide the pad out of its channel in the midframe.
  26. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 26 단계, 이미지 3개 중 1개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 26 단계, 이미지 3개 중 2개 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: 26 단계, 이미지 3개 중 3개
    • Slide the L1 and L2 button pad out of its channel in the midframe and remove it.
    • Each pad has two plugs and an upper groove to align it with the midframe. During reassembly, ensure the plugs are inserted in their holes and the groove is hooked onto the tab in the midframe.
결론
다른 45명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
96,048 평판
안내서 466개를 작성함
2가이드 댓글
Rimettere quella piccola molla è praticamente impossibile 😭
Clash Royale - 답글
ma scusate perché disassemlare tutto il pad?
rain naxiil - 답글
댓글 쓰기
조회 통계:
지난 24시간: 30
지난 7일: 263
지난 30일: 1,126
전체 시간: 122,177
