주요 콘텐츠로 건너뛰기
DualShock 4 CHU-ZCT2U Battery Replacement
필요한 것
  1. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel screws: 1 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel screws: 1 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Battery Replacement, Separate the rear panel: 2 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Battery Replacement, Separate the rear panel: 2 단계, 이미지 2/2
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Battery Replacement, Release the plastic clips: 3 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Battery Replacement, Release the plastic clips: 3 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Battery Replacement, Release the plastic clips: 3 단계, 이미지 3/3
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel: 4 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel: 4 단계, 이미지 2/2
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Battery Replacement: 5 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Battery Replacement: 5 단계, 이미지 2/2
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
  6. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the battery: 6 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Battery Replacement, Remove the battery: 6 단계, 이미지 2/2
    • Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
  7. DualShock 4 CHU-ZCT2U Battery Replacement: 7 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Battery Replacement: 7 단계, 이미지 2/2
    • Remove the battery.
결론
다른 24명이 해당 안내서를 완성하였습니다.
Sam Omiotek
회원 가입일: 02/25/19
72,896 평판
안내서 288개 작성하였습니다
댓글 3개
For this DualShock 4 CHU-ZCT2U Battery Replacement, shouldn’t the battery model be JDM-040 and not JDM-030 for this controller. I ordered the battery listed but the connector was too large. So I believe this needs to be edited to match accordingly to avoid confusion and incorrect orders. Thanks!
Tom Nguyen - 답글
Good catch! I just pulled apart the ZCT1U and ZCT2U models and you are right. I will fix this in the guide. Thank you!
Sam Omiotek -
Can perhaps someone tell me what exact connector does the original battery use ?
MCQ - 답글
댓글 쓰기
조회 통계:
24 시간 전: 17
7일 전: 166
30일 전: 866
전체 시간: 24,852
