주요 콘텐츠로 건너뛰기
Dymo LabelManager 160 Charging Port Replacement
필요한 것
  1. Dymo LabelManager 160 Charging Port Replacement, Batteries: 1 단계, 이미지 1/1
    • Place the device face-down to access the battery compartment.
  2. Dymo LabelManager 160 Charging Port Replacement: 2 단계, 이미지 1/1
    • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
  3. Dymo LabelManager 160 Charging Port Replacement, Keyboard: 3 단계, 이미지 1/1
    • To open the cartridge compartment, simply lift on the front of the device.
  4. Dymo LabelManager 160 Charging Port Replacement: 4 단계, 이미지 1/2 Dymo LabelManager 160 Charging Port Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
  5. Dymo LabelManager 160 Charging Port Replacement: 5 단계, 이미지 1/1
    • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
  6. Dymo LabelManager 160 Charging Port Replacement: 6 단계, 이미지 1/3 Dymo LabelManager 160 Charging Port Replacement: 6 단계, 이미지 2/3 Dymo LabelManager 160 Charging Port Replacement: 6 단계, 이미지 3/3
    • Gently remove the rubber keyboard from the device.
  7. Dymo LabelManager 160 Charging Port Replacement, Charging Port: 7 단계, 이미지 1/1
    • Use wire cutters or scissors to cut the wires attached to the charging port, and remove the charging port.
  8. Dymo LabelManager 160 Charging Port Replacement: 8 단계, 이미지 1/1
    • Use wire strippers to strip the end of each wire.
  9. Dymo LabelManager 160 Charging Port Replacement: 9 단계, 이미지 1/1
    • Solder the black wire to the bottom-most node of the new charging port. Solder the red wire to the uppermost node of the new charging port. See the following link for soldering tips: How To Solder and Desolder Connections
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Ozga
회원 가입일: 03/02/17
170 평판
안내서 1개 작성함
IUPUI, Team S3-G4, Harley Spring 2017 IUPUI, Team S3-G4, Harley Spring 2017 회원
IUPUI-HARLEY-S17S3G4
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 15
전체 시간: 880
