주요 콘텐츠로 건너뛰기
Dyson DC24 Ball Lower Small Bearing Replacement
필요한 것
  1. Dyson DC24 Ball Lower Small Bearing Replacement, DC24 Ball's Lower Small Bearing: 1 단계, 이미지 1개 중 1개
    • Recline vacuum all the way to expose as much of the ball as possible.
  2. Dyson DC24 Ball Lower Small Bearing Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Torx screwdriver, remove the four screws that hold both sides of the ball together.
  3. Dyson DC24 Ball Lower Small Bearing Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the end of the lower duct hose to reveal a torx screw.
    • Remove the screw that holds the motor to the axel.
  4. Dyson DC24 Ball Lower Small Bearing Replacement: 4 단계, 이미지 2개 중 1개 Dyson DC24 Ball Lower Small Bearing Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the three torx screws on the otherside.
    • Then remove the cover which will reveal some power cables.
    • Then remove the last screw that holds the motor to the axel.
  5. Dyson DC24 Ball Lower Small Bearing Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the post motor filter.
    • Carefully pull the axel out of its hole and down.
  6. Dyson DC24 Ball Lower Small Bearing Replacement: 6 단계, 이미지 2개 중 1개 Dyson DC24 Ball Lower Small Bearing Replacement: 6 단계, 이미지 2개 중 2개
    • Place the new bearing on the axel. (It doesn't matter which way it goes on)
  7. Dyson DC24 Ball Lower Small Bearing Replacement: 7 단계, 이미지 2개 중 1개 Dyson DC24 Ball Lower Small Bearing Replacement: 7 단계, 이미지 2개 중 2개
    • When reassembling, it is easiest to put the vacuum in its upright position to insert the axel screws.
    • The red arrow points to the type of torx screws that hold the motor in place while the orange arrow points to the type that hold the orange ball together.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
ForumHermit
회원 가입일: 08/16/13
1,784 평판
안내서 2개를 작성함
4가이드 댓글
When replacing the bearings, is there only one small bearing set to replace or are there two sets, one on each side? If there are two, should they both be replaced?
Josh McCanless - 답글
I believe there is only one you need to replace. This was a common issue with the DC24.
ForumHermit -
Thanks for the guide. $20 for the part and 20 minutes later, I saved myself $400.
You, sir, are awesome.
Bless you for the guide.
Josh McCanless - 답글
No worries! I made this guide to help people do that exact thing.
ForumHermit - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 31
전체 시간: 5,974
