주요 콘텐츠로 건너뛰기
Dyson V8 Animal Battery Replacement
필요한 것
  1. Dyson V8 Animal Battery Replacement, Bin: 1 단계, 이미지 1/2 Dyson V8 Animal Battery Replacement, Bin: 1 단계, 이미지 2/2
    • Push the red button and slide the connecting shaft off.
    • The shaft must be held from moving when disconnecting from the motor.
  2. Dyson V8 Animal Battery Replacement: 2 단계, 이미지 1/3 Dyson V8 Animal Battery Replacement: 2 단계, 이미지 2/3 Dyson V8 Animal Battery Replacement: 2 단계, 이미지 3/3
    • Pull up on the red tab and continue to slide the motor completely up.
    • The dust bin will open on the bottom.
  3. Dyson V8 Animal Battery Replacement: 3 단계, 이미지 1/2 Dyson V8 Animal Battery Replacement: 3 단계, 이미지 2/2
    • Push the red tab down.
    • Pull the dust bin out from the handle head.
  4. Dyson V8 Animal Battery Replacement, Battery: 4 단계, 이미지 1/2 Dyson V8 Animal Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Push down on the red tab.
  5. Dyson V8 Animal Battery Replacement: 5 단계, 이미지 1/2 Dyson V8 Animal Battery Replacement: 5 단계, 이미지 2/2
    • Push down on the red tab on the other side.
    • Pull the motor away from the handle.
    • You may need to hold down the handle while sliding the motor off.
  6. Dyson V8 Animal Battery Replacement: 6 단계, 이미지 1/2 Dyson V8 Animal Battery Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove two 18 mm screws on the bottom of the battery.
  7. Dyson V8 Animal Battery Replacement: 7 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove one 18 mm screw on the back of the handle.
  8. Dyson V8 Animal Battery Replacement: 8 단계, 이미지 1/2 Dyson V8 Animal Battery Replacement: 8 단계, 이미지 2/2
    • Slide the battery out from handle.
    • The handle must be held from moving while sliding the battery out.
결론
다른 11명이 해당 안내서를 완성하였습니다.
AJ McLean-Scholz
회원 가입일: 01/23/20
723 평판
안내서 5개 작성하였습니다
Cal Poly, Team S19-G1, White Winter 2020 Cal Poly, Team S19-G1, White Winter 2020 회원
CPSU-WHITE-W20S19G1
4 회원들
안내서 10개 작성하였습니다
댓글 5개
Replacement Vacuum Cleaner Batteries for Dyson V8 Animal
Battery Type:   Li-ion
Voltage:   21.6V
Capacity:   4000mAh
Color:   Grey
Weight:   770.26g
Dimensions: 145.00 x 90.10 x 115.90mm
If you intereted in this battery, please view more info on http://www.drillbattery.com.au/orderbatt...
Drillbatterycomau - 답글
Thankyou! I'll be able to replace the battery soon.
Olivia Swift - 답글
This worked for the V7 Animal model just fine. Very easy and clear, thank you!
Katie - 답글
Thank you. These instructions just helped me to replace the worn out battery on our V8 Animal in 5 minutes! Now it's humming along again with 3 blue bars. Great! (Note: I was concerned I might strip the screw head but I just pressed harder while turning and the screwdriver did not slip. Then I saw that the replacement battery came with four new replacement screws. So, it's all good.)
Neill Graham - 답글
I have a stripped screw that won't extract. I have already drilled the hole ho so now no screwdriver will work. Any suggestions?
christina - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 42
30일 전: 163
전체 시간: 7,019
