주요 콘텐츠로 건너뛰기
Dyson V8 Animal Brush Bar Replacement
필요한 것
  1. Dyson V8 Animal Brush Bar  Replacement, Brush Bar: 1 단계, 이미지 1/1
    • Push the red button and then slide the brush head off of the shaft.
    • The shaft must be held from moving when sliding the brush head off.
  2. Dyson V8 Animal Brush Bar  Replacement: 2 단계, 이미지 1/3 Dyson V8 Animal Brush Bar  Replacement: 2 단계, 이미지 2/3 Dyson V8 Animal Brush Bar  Replacement: 2 단계, 이미지 3/3
    • Insert a coin into the slot on the side of the brush head.
    • Turn the coin counter clock wise to unlock the brushbar.
    • Pull the brushbar straight out of the brush head.
    • Clean all debris off of the brushbar and from inside the brush head.
    • The brushbar will spring outwards slightly when unlocked successfully.
결론
다른 2명이 해당 안내서를 완성하였습니다.
AJ McLean-Scholz
회원 가입일: 01/23/20
723 평판
안내서 5개 작성하였습니다
Cal Poly, Team S19-G1, White Winter 2020 Cal Poly, Team S19-G1, White Winter 2020 회원
CPSU-WHITE-W20S19G1
4 회원들
안내서 10개 작성하였습니다
댓글 4개
Did that but brush still will not spin.
walt.florence - 답글
I can't remove the brush, it springs outwards but keep firmly attached to the "axis". I've also tried to remove the transparent cover, by removing all the screws I've found on it (6 in total) but seems impossible. Can anyone please post a step by step guide about how to dissemble the whole brush bar??
Henar Lanchas López - 답글
I’m saving my Pennys for the “coin tool”. It does seem hauntingly familiar however….
Enrico Crocetti - 답글
I am unable to insert a coin into the slot provided. No problem previously
Mgt trotter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 29
30일 전: 145
전체 시간: 4,979
