소개
It is a little tricky to set the ECAM models with touch display to test mode. These instructions show you how to do this. You can use the test mode to quickly check the function of the most important components. For models with "real" buttons, see here.
When the machine is switched on, press the off-switch until the machine goes into standby mode and the display turns off.
There has to be water in the water tank, the drip tray is initially still inserted. The power plug remains in the outlet.
Work through the steps in reverse order to reassemble your device.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
