주요 콘텐츠로 건너뛰기
EVGA x17 Scroll Wheel Replacement
필요한 것
  1. EVGA x17 Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 1개 중 1개
    • Remove the mouse skates to reveal 5 screws.
  2. EVGA x17 Scroll Wheel Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the 5 screws that secure the bottom panel.
  3. EVGA x17 Scroll Wheel Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the weight chamber cover.
  4. EVGA x17 Scroll Wheel Replacement: 4 단계, 이미지 1개 중 1개
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
  5. EVGA x17 Scroll Wheel Replacement: 5 단계, 이미지 2개 중 1개 EVGA x17 Scroll Wheel Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the 13 screws on the interior.
    • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
  6. EVGA x17 Scroll Wheel Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully slide middle section out.
    • Remove smaller sized cross head screws from piece labeled AZAC001-A V1.0.
  7. EVGA x17 Scroll Wheel Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the transistor from the side of the mouse wheel.
  8. EVGA x17 Scroll Wheel Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully slide a spudger between the opaque plastic that holds the scroll wheel in place.
    • Pry the plastic away from the wheel, allowing for the scroll wheel to be removed.
  9. EVGA x17 Scroll Wheel Replacement: 10 단계, 이미지 2개 중 1개 EVGA x17 Scroll Wheel Replacement: 10 단계, 이미지 2개 중 2개
    • Remove scroll wheel cover and replace plastic wheel (or cover if that appears to be the issue).
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sydney Puett
회원 가입일: 09/13/23
604 평판
안내서 3개를 작성함
2가이드 댓글
Is there a wheel that can be purchased that will fit or can be modified to fit for the replacement.
Ronald Winfrey - 답글
The only solution I've found so far is to 3D print the wheel. Now, my X17 mouse is working.
Carlos Pavon -
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 25
지난 30일: 99
전체 시간: 2,355
