주요 콘텐츠로 건너뛰기
Eclipse 180G2 MP3 Video Player speaker Replacement
필요한 것
  1. Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: 1 단계, 이미지 1/2 Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: 1 단계, 이미지 2/2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: 2 단계, 이미지 1/3 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: 2 단계, 이미지 2/3 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: 2 단계, 이미지 3/3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  3. Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: 3 단계, 이미지 1/2 Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: 3 단계, 이미지 2/2
    • Identify the speaker. Pull the speaker away from the device so that wires are exposed.
    • Using a wire cutter, sever the red and black cables that are connecting the speaker to the circuit board.
    • You will need to solder the new speaker wires to connect it to the device.
결론
  • To reassemble your device after completion of replacement, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Jesse Minor
회원 가입일: 01/15/15
662 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-4, Tanski Winter 2015 USF Tampa, Team 1-4, Tanski Winter 2015 회원
USFT-TANSKI-W15S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 21
전체 시간: 888
